# Connect & Migrate Everything
> Use the Connect Everything skill in Teable AI Chat to connect and migrate Airtable, Baserow, SmartSuite, NocoDB, APIs, databases, and more into Teable.
**Connect Everything** is a [Teable AI Chat](/en/basic/ai/ai-chat) skill for connecting external systems and migrating their data into Teable.
<CardGroup cols={2}>
  <Card title="Migrate Airtable" icon="table" href="/en/basic/ai/connect-everything/migrate-airtable">
    Move token-accessible Airtable data and structure into Teable.
  </Card>
  <Card title="Migrate Baserow" icon="table" href="/en/basic/ai/connect-everything/migrate-baserow">
    Connect a Baserow instance and migrate accessible databases.
  </Card>
  <Card title="Migrate SmartSuite" icon="table" href="/en/basic/ai/connect-everything/migrate-smartsuite">
    Connect SmartSuite with an API key and Workspace ID.
  </Card>
  <Card title="Migrate NocoDB" icon="table" href="/en/basic/ai/connect-everything/migrate-nocodb">
    Connect a NocoDB instance and migrate accessible bases.
  </Card>
  <Card title="Connect & Migrate More Sources" icon="plug" href="/en/basic/ai/connect-everything/more-sources">
    Connect APIs, databases, SaaS tools, and other authorized sources.
  </Card>
</CardGroup>
## How it works
1. Open [Teable AI Chat](/en/basic/ai/ai-chat).
2. Type `/` and select **Connect Everything**.
3. Provide the source URL and required token or credentials.
4. Tell Teable AI what to migrate, then review the result.
Depending on what the source exposes, Teable AI can migrate data, records, tables, field types, and relationships. Coverage depends on the source API and the permissions granted to the connection.
