# Connect AI Agents to Teable
> Query and update data, manage tables, and create automations or apps from your AI agent.
## Install Teable Skill
Copy this prompt into your AI agent:
```text wrap theme={null}
Please read https://github.com/teableio/agent-skills, follow the guide to help me install the Teable agent skill, and complete Teable CLI authentication.
Or install it directly:
```bash theme={null}
npx skills add https://github.com/teableio/agent-skills
## Try Teable Skill
After the skill is installed, try these prompts.
<CodeGroup>
  ```text Simple Starter Prompts wrap theme={null}
  Create a simple CRM table in <Base> {paste Base URL}.
  ```text Local Files → Teable wrap theme={null}
  Upload all invoices in this local folder to <Receipt Table> {paste table URL} and extract key fields.
  ```text Cross-Platform Data → Teable wrap theme={null}
  Import new GitHub issues into <Bug Tracker> {paste table URL}.
  ```text Clean Or Organize Teable Data wrap theme={null}
  Check <Task Table> {paste table URL} and mark overdue tasks.
</CodeGroup>
