Connect Everything is a Teable AI Chat skill for connecting external systems and migrating their data into Teable.
How it works
  1. Open Teable AI Chat.
  2. Type / and select Connect Everything.
  3. Provide the source URL and required token or credentials.
  4. Tell Teable AI what to migrate, then review the result.
Depending on what the source exposes, Teable AI can migrate data, records, tables, field types, and relationships. Coverage depends on the source API and the permissions granted to the connection.
