Install Teable Skill
Open your avatar at the bottom left → Settings → Developer tools → Teable Skill to copy the installation prompt or command for your current Teable instance. Copy this prompt into your AI agent:Try Teable Skill
After the skill is installed, try these prompts.Develop Apps Locally
With the Teable skill installed, AI agents such as Claude Code and Codex can work on App Builder apps on your computer. The agent uses the Teable CLI to create an app or clone an existing app’s code, and each push is saved as a new app version, which the agent can also publish. Working on an existing app requires edit access to it.Connect Through MCP
MCP clients such as Claude Code, Cursor, Codex, and claude.ai can also connect to Teable’s MCP server directly, without installing the skill. From the client, you can view project and table structure, read and write records, and call the Teable API. The client acts as you, with the same permissions you have in each project.1
Open MCP settings
Click your avatar in the lower left, then open Settings → Developer tools → MCP. Under Add the server to your client, the page has a tab for each client: Claude Code, Codex, Cursor, and Other. Each tab gives the command or configuration for that client, and the Server URL appears on the Other tab.
Choose your client and copy the command or configuration from the page. For Claude Code, the command on the page already includes the server URL. Copy it and run it in a terminal:
Sign in and authorize
On first connection, the client opens a browser. Sign in to Teable, select I recognize and trust this URL, and click Continue to finish authorizing.
Authorization header. MCP lists only the tools the token’s scopes allow, and checks every call against them: for every tool, create a token with Full access permissions and All spaces and projects access; if the client only needs some projects, choose Specific spaces or projects and grant only the permissions it needs. The command or configuration shown there follows the client tab you selected.
